JBRDH
not knowing which ones id need, i left them in the spare... from what ive seen...it looks like the longer ones that are stock on the xfire will work wiht this spare...
JBRDH, Just whenever you get the chance would you measure
the length of the shaft on one of the bolts in your "temporary" spare wheel? (The shaft is BOTH the threaded & non-threaded section that is "straight", and located beneath the head & the flange)
BTW, OE Crossfire lug bolts are M12-1.50, 22.5mm Ball seat flange,
39.4mm shaft, 17mm hex head
