Old Jan 1, 2022 | 12:48 AM
Bzak1pgh's Avatar
Bzak1pgh
Default Re: Dash lights go crazy, stuck in first gear, BAS light on and off
This is not a wheel speed sensor.
P0335 usually means a bad Crank Sensor.
But the P0600 is another matter, it points to failed communications between modules but does not tell us which modules, you can assume it's failed communications from the ECU to another module.
Given the lights coming on like that I'd suggest the following:
1) Replace the Crank Sensor with a Bosch part from German Auto Supply, FCP Euro, etc.
2) Replace the RCM or send it to DJ for evaluation (he will replace bad relays and reflow any suspect solder paths).
3) I'd take a REAL close look at battery post connections, and the ground from the block to chassis or maybe install one of these modifications:
https://www.crossfireforum.org/forum...le-engine.html
I get the idea you have failing power to the ECU/Brake Controller/TCU/Instrument panel, this can be in the RCM or in the electrical (battery/alternator) system in general.
Ok, I'll start with the Crankshaft Position Sensor and then do the module. Do u have the contact info for the guy who does the RCM? And lastly, THANK YOU!!! I've read a lot on the forums but they all hit around my issues with my son's car but not exactly what's happening, and dealships around here are useless....
