Old Jan 3, 2022 | 10:33 PM
onehundred80
Default Re: Transmission Fluid surprise
Originally Posted by Nynick8
Hello! I find it interesting about the transmission dipstick. Do you have any other info or links? Once the dipstick is purchased, where in the engine/tranny does it fit?
It does not go anywhere, you hang it in your garage. You can get a cheap one from China for less than $10
You can remove the dipstick hole cover if you know the trick of how break the seal and use it again, the instructions are on the forum somewhere or you can buy anew cover, they are cheap enough. Do not use a loose cover.
