Transmission Fluid surprise
Old Dec 27, 2021 | 07:49 PM
BigGameWayne's Avatar
Unhappy Transmission Fluid surprise
2005 Roadster sat in garage for a few months and found a small puddle of transmission fluid under the car. 36k miles automatic
Car would start but wouldn't go into gear. Any ideas what to deal with first? Appreciate some help
Old Dec 27, 2021 | 11:23 PM
Default Re: Transmission Fluid surprise
are you saying the shifter does not move or when u shift the transmission does not engage engine thinks it is in neutral ? also where in fl
Old Dec 28, 2021 | 06:00 AM
The shifter does engage and the car does go into gear but there is fluid under the car(a few ounces) and since there is no dip stick I'm not sure how much is left and should i drive it to the mechanic(10 miles) or tow it. The shifter was an effect from the lock button accidently being on the dash. Why is there a lock button anyway?
Old Dec 28, 2021 | 08:24 AM
Fla_Xfire_SRT's Avatar
>>Wayne, you wrote..."The shifter was an effect from the lock button accidently being on the dash. Why is there a lock button anyway?"
~~ What lock button on the dash are you referring to?
>> Are you near Ocala or The Villages? Perhaps I can help. More than likely, the puddle is a result of the "O" ring failure at the point where the Transmission harness cable inserts into the transmission. There is an "O" ring that fails and will leak, if left in this condition for too long, it is possible for the fluid to "wick" up to the transmission control module and ruin it. It is an easy and cheap fix. There are dip sticks available for our cars. Rob at NeedsWings dot com has them. Temperature of the fluid is important when reading the dip stick.
Old Dec 29, 2021 | 08:05 PM
Deepsea21's Avatar
Got to drive that car more. A 2005 with only 36K on the clock? The lack of driving it and bringing everything up to normal operating temps is killing it. Gaskets, hoses, bushings and seals throughout are probably dry-rotting. You couldn't pay me to buy a XF with 5 miles on the clock that has been sitting for 15+ years. What a nightmare that would be. Don't let it sit... Drive it more.
Old Dec 30, 2021 | 09:59 PM
Wadsworth's Avatar
I bought one with 3700 miles 4 years ago. Pushing 16,000 miles now. Would not hesitate to do it again. I would hop into it right now and drive cross country.
The O-ring on the transmission communication cable is a well-known problem with the 722.6 transmission.
Old Dec 31, 2021 | 07:48 AM
~ This was an inspiring thread, it made me think of the 43K mile SSB roadster in the garage that I haven't cranked in many months. It made me feel a bit guilty, So, I did and felt much better about letting it sit. I should crank it more often.
Old Jan 3, 2022 | 10:06 PM
Nynick8's Avatar
Hello! I find it interesting about the transmission dipstick. Do you have any other info or links? Once the dipstick is purchased, where in the engine/tranny does it fit?
Old Jan 3, 2022 | 10:33 PM
It does not go anywhere, you hang it in your garage. You can get a cheap one from China for less than $10
You can remove the dipstick hole cover if you know the trick of how break the seal and use it again, the instructions are on the forum somewhere or you can buy anew cover, they are cheap enough. Do not use a loose cover.
Old Jan 3, 2022 | 11:00 PM
Nynick8's Avatar
Thank you! Yes that really is interesting.... I hope I never need to do that. I just had the fluid flushed first time ever @ 115k miles (and it needed it)... so now I hope I never have to deal with the transmission again
syfi
Mar 28, 2026 04:14 PM
crossdude
Jul 18, 2021 09:55 AM
Donkeyface
May 8, 2021 11:01 PM
tje275
Jul 6, 2018 08:21 AM
prodro1488
Oct 18, 2010 05:21 PM
