nemiro
Which Optima battery did you go with? I have thought about relocating my battery to the same place, to free up room for a water tank for a Killer Chiller.
I’ll double check as I had the office parts guy order it for me. I believe an h6 size yellow top.
we stock dekka batteries but I want one I don’t need to bother venting.
I ran the cables up the passenger side. No holes had to be drilled. Did not take out passenger seat. Removed sill plate, kick panel and under dash cover.
there is a rubber grommet under the battery tray by the factory amplifier location that you can run them through. I used 1gauge. 300 amp fuse at new battery.
