Rbegora
Since the top does not go up, am I correct in assuming the top open switch is not the problem?
Thanks for any help.
The top open and divider switches are not "polled" when you hit the button to put the top UP. So, we have something else going on here.
Im on a road trip, stopped for lunch. I'll be on here EARLY tomorrow morning and post more.
But here's a few things:
1) Do the door locks all work?
2) Does the wing act normally (in Base and Limited models only, SRTs dont have a powered wing).
If either answer is "No", I'd yank the trim from the trunk and look for water intrusion to the Central Locking pump/Security System Module.
You should probably also look at fluid level in the tank, but Im not thinking that is the problem.
I'll be back in aabout 18 hours...
