Old Jun 16, 2022 | 12:06 AM
onehundred80
Default Re: Key fob transfer now unlock/lock does not work
Originally Posted by TNT
So here is the funny thing. I have a SRT6 and a 2004 limited. SRT had two sets of keys I recently switched to new cases due to wear and then the Limited key, that doesn’t work anymore.
None of those three keys lights up when I hold down any buttons.
‘I also don’t see How there could be a led light up under that red plastic cover, as there aren’t any LEDs underneath that cover from when I took it apart. Or am I missing something?
The two SRT keys I swapped into the new black key fob case both work just fine but also No led when I press the lock/unlock buttons.
Any help is much appreciated.
The LED is not large and it sits at the forward narrow end of the board in the chip area.
The light flashes dimly a couple of times then flashes brightly once. You would probably have to be in the dark to see the dim flashes. All my fobs have flashed when you hold a button down for a second or two, do not press the panic button though.😉
You can see it in one of the photos in the sticky post that shows you how to change the cases, it shows up as a white square I think.
