Old Jun 16, 2022 | 01:14 PM
nickwe21.'s Avatar
nickwe21.
Default Re: Key fob transfer now unlock/lock does not work
The LED is not large and it sits at the forward narrow end of the board in the chip area.
The light flashes dimly a couple of times then flashes brightly once. You would probably have to be in the dark to see the dim flashes. All my fobs have flashed when you hold a button down for a second or two, do not press the panic button though.😉
You can see it in one of the photos in the sticky post that shows you how to change the cases, it shows up as a white square I think.
Gonna try that tonight. I'll just try all three to see the difference because two work (the SRT6 ones) the limited doesn't. Will report back
