Old Aug 23, 2022 | 04:02 PM
  #101 (permalink)
Buck62's Avatar
Buck62
Default Re: How can I disable the TPMS? (Tire Pressure Monitoring System)
Sounds like you have given your awl but still come up short. At the bottom of the rectangular slots in the side is a little tang on the contact that springs into that slot when it reaches it when the contact is pushed in. All you have to do is push the tang so that it is in as far as it will go while pulling on the wire, it is best done if you can rest the plug against the housing as you do not what to slip and only succeed in pulling the screwdriver out of your hand.
If this fails cut the wire 2” or so from the plug and tape the ends of. Maybe the next owner can fix it correctly or ignore it.
Good luck.
Thanks... I'll give it one last shot with your advice...with a major problem being that my 60 year old eyes are bugging out of my head and I can barely see this stuff, even with a magnifying glass.
If I can't get it, the wire shall be cut as I use a wide range of four letter words upon it.
