rtravelbee
no engine bay light, no trunk light. Who would have thunk it..... I did get on NeedsWings website and discovered I could get a key. Now if I could get a driver side speaker ring I would be in 7th heaven. I have received a couple off a couple of guys on this website but I believe there is a difference between the passenger side and the driver's side. Lastly... what is the CLP/SSM and since my panic button does not work should I order a siren from NeedsWings?
Everyday is a new learning experience from a really fun car...
NO engine bay light, but all Roadsters have a trunk light. (Not sure on coupes, never had one).
CLP/SSM is the central locking pump/security system module in the trunk / right wheel area that contains the pump to operate the locks but it also has a CAN BUS communication module and other electronics that enable it to talk to the SKREEM, Top Module and Body Control Module.
A bad PANIC button is often a bad key fob itself. If the siren does not go off and the lights don't flash, it's not the siren, it's either the fob or an issue with the SKREEM. If you get lights flashing but no siren, they it could be a bad siren.
