GraphiteGhost
There are a number of 'electric seat' fault issues here in the forum posts with solutions as listed. One suggests a bad diode in the seat relay. As I just gave you the one instance, finding out what is causing the seat(s) issue is important to solving the problem. I have no idea what you're going to do with this ebay item but wiring in something like this might cause you more problems. Unless that relay is an exact replacement you're going to cause a huge can of worms (especially wire worms) and just might cause more electrical problems. Good luck in whatever you do, I hope it solves your problem with the seat issue. Check the forum document collection for the issues many of the members had and solved. It just might save you a lot of money and headaches.
OK point taken! I received a 5-pin relay from Erroneous Bay (to e fair I've had plenty of good stuff), that I suspect will not be suitable as surely more pins are required for the power seat relay - unless there are 2 of them? As both seats have failed, I suspect not. I have searched on the manufacturer codes placed elsewhere on this site, but no line of sight in the UK. Does anyone have a pin layout and rating, or something to point me to an equivalent part please?
With the drivers seat fixed at full extent, as it is now, I can't expect the wife to not be able to see over the dashboard at full throttle! That would be dangerous and I love her too much!
