Thread: help tpms
Old Oct 26, 2022 | 01:02 PM
dedwards0323
Default Re: help tpms
I don't understand how that works. It was my understanding that the magnet "woke up" the sensor so that you could talk to it, as the sensor is supposed to have a built-in "on-off" switch that operated when the tire rotated, so the sensor was 'off' when the car was not moving, saving the battery. Since you can talk to the sensor at any time, what I understood to be the way it works is not accurate.
Essentially, the Autel scanner "triggers" the wheel sensor by sending a signal to it when the DRB3 software says it's ready (beep) to receive the sensor's info. So it is essentially performing the same task as the magnet.
See attached document.
File Type: pdf
