help tpms
Old Oct 24, 2022 | 01:58 PM
far103's Avatar
Smile help tpms
tpms batterys just died on my 2005 SRT and I don't want to go to the S.O.B. dealership.need relearn on computer for new sensors. HELP any one around or near port orange FL that does have data cable & software so I can get rid of light on dash
Old Oct 24, 2022 | 05:43 PM
Default Re: help tpms
What sensors did you buy? And why did the place that installed them not program them to the car?
I Know the answer to the second question: Because they sold you the wrong sensors, thinking you had a typical TPMS system. But you dont, you have the abortion known as the CROSSFIRE system and there is, I do believe, only one sensor that works.
So, where did you get them and what did they sell you?
Old Oct 24, 2022 | 06:02 PM
far103's Avatar
factory mopar part #1-52088990ae made in Ireland and he did not have the equipment
Old Oct 24, 2022 | 06:04 PM
far103's Avatar
I purchased them my self
Old Oct 24, 2022 | 07:43 PM
THose are the right ones.
You might find this helpful, Clint was on the engineering team for the TPMS and SRS systems when the Crossfire was developed.
File Type: pdf
Old Oct 25, 2022 | 06:43 PM
I Know the answer to the second question: Because they sold you the wrong sensors, thinking you had a typical TPMS system. But you don't, you have the abortion known as the CROSSFIRE system and there is, I do believe, only one sensor that works.
Actually any sensor that is the proper frequency can be activated and linked to the TPMS Module using the DRB3 Emulator software. I've done this multiple times with various sensors for several folks & cleared the TPMS warning light on the dash. The Autel scanner I have doesn't require the magnet to trigger the sensor for the DRB3 Emulator software to store the sensor's info. The Autel scanner tool has the capability to trigger the sensor all by itself, working with the DRB3 Emulator software, & will store the sensors' IDs & info parallel to the TPMS Module. I've saved the sensor info and sent copies to the various owners for their records. And if the new sensors are Autel, the existing wheel sensors can be cloned by the Autel scanner so the TPMS Module doesn't know the difference between old & new.
Unless I'm missing something in far103's opening post.
Old Oct 25, 2022 | 09:58 PM
far103's Avatar
I got the factory Schrader sensors
Old Oct 26, 2022 | 08:56 AM
The DRB3 Emulator should be able to read these easily. You just need to find someone close to you that has the software and pick a place to meet to fix your TPMS system.
Old Oct 26, 2022 | 09:43 AM
I don't understand how that works. It was my understanding that the magnet "woke up" the sensor so that you could talk to it, as the sensor is supposed to have a built-in "on-off" switch that operated when the tire rotated, so the sensor was 'off' when the car was not moving, saving the battery. Since you can talk to the sensor at any time, what I understood to be the way it works is not accurate.
Old Oct 26, 2022 | 01:02 PM
Essentially, the Autel scanner "triggers" the wheel sensor by sending a signal to it when the DRB3 software says it's ready (beep) to receive the sensor's info. So it is essentially performing the same task as the magnet.
See attached document.
File Type: pdf
Old Oct 26, 2022 | 01:59 PM
Here's the latest TPMS Relearn Results on my 2007 Coupe.
Status of TPMS wheel sensors on 2007 XFire Coupe.
TPMS wheel sensors info - Screen #1
TPMS wheel sensors info - Screen #2
An interesting fact that surfaced. The DS of my Coupe still has the factory OEM wheel sensors installed and they function fine. The PS wheel sensors both failed a couple of years back & I replaced them with VDO REDI-Sensors (SE100004A; 433 MHz). I set the air pressure in all 4 tires at 36 PSIG. The OEM sensors measure high; the VDO sensors measure low. But both are shown as fully functional & within tolerance.
The Autel also has a feature where it will check the status of the battery in the key fob. You set the scanner tool to the key test function, hold the fob near the scanner & press one of the fob buttons (lock or unlock). The scanner sees the signal & shows me how strong the battery is. Right now my wife' fob shows 48-51% power & tells me the signal triggers at 315 MHz.
Oh by the way, the Autel scanner tool came with the wheel magnet. Sorry for digressing.
Probably ought to put together a "sticky" thread where we can list Owners (dedwards0323) with locations (Upstate SC) that have the DRB3 Emulator w/Micropod 2 (or other TPMS capability). That way folks could reach out to a nearby Owner & get some help on performing the relearn process on the Crossfire TPMS system & clear the dash warning light.
Xtreme
295
Feb 19, 2026 10:59 PM
20
Jan 18, 2023 09:18 PM
rabatts
Mar 22, 2015 09:32 AM
jefftalexander
Jan 25, 2013 03:14 PM
