Old Oct 27, 2022 | 11:20 AM
Ronman's Avatar
Ronman
Default Re: Crossfire Heating problems
Leaving the windows closed with the heat on has a tendency to remove a lot of humidity (it is always good to remove excess humidity in a vehicle, right?). OR, It'll allow the systems sensors less time to fully settle down without any outside air temperature influence (which makes more sense being it is a dual zone system with a common ductwork return).
Yes but you didn't read the entire thread. This is to unclog a stuck duo valve not for normal heating.
