Old Nov 20, 2022 | 08:48 PM
Matticmass's Avatar
Matticmass
Default Re: Help! Spoiler deployed, won't retract
Originally Posted by FinUp
I have the same issue as this Member. What corrected the problem? The red LED is blinking on the spoiler control switch. It does operate okay using the Manual Switch. Its goes down, and pops right back up again. My situation is identical to another member too, I had my car painted and now the Spoiler won't stay down. The Spoiler Switch is stuck in the Up Position. I have replaced fuses, but the Spoiler Switch won't rock back and forth. My car is 2005. The battery was replaced in May 2010. Any new suggestions? BTW, my Username is FinUp, but I TRULY don't want it to stay that way !!! Thanks.
I have the same issue and can’t seem to find a resolution. It will deploy at 65mph but won’t retract. The light will flash. If I turn the car off the back on I can step it down with the manual switch. Once retracted I have to count 3 seconds then press the down switch again to lock it in position. Any help would be appreciated.
