Old Nov 27, 2022 | 06:18 PM
Heli-Cal Blue's Avatar
Heli-Cal Blue
Default Re: Temporary power fade
And if you just put the booster on, even in the last month or so, I"d yank it out and see if that clears it. Any symptoms that start right after a mod are usually related to the mod.
Thank you - no, it's been on there a while, no problems. I even posted about it here when I installed it. Link below - that was 2018. HOWEVER.... I just went out to the car just now, after it's been sitting for the past couple of hours, and with the Sprint Booster function turned off entirely, the car drove fine for about 3 miles, no issues - but the Check Engine light was on. Then upon returning home, I turned off the car, waited a few minutes, and then turning it back on the Check Engine light is now off.
I won't have time to mess with it today, but I think next weekend I'll remove the Sprint-Booster connector entirely to see if that is causing trouble and order/buy a code-reader in the mean-time.
I still want to get a good code-reader though, but there are so many variations/types it's a bit perplexing on which one to get.
https://www.crossfireforum.org/forum...tml#post906619
