Old Jan 6, 2023 | 06:25 PM
Romad's Avatar
Romad
Default Re: SKREEM Conumdrum!
Perhaps the switched power to the SKREEM that powers the second function is failing at times (bad ignition switch?) I doubt that is the case. But fact is, the SKREEM does two jobs - do the lock/unlock buttons always work or do they sometimes give you trouble as well?
Yes I talked to MSS when I asked for a quote and he also said that based on my classic info that it indeed might be a faulty SKEEM module. He said that next time I get the no start conditions to remove the battery ground for 15 seconds and then reconnect. If problem still persists it "is" the SKREEm module. It has been starting several times properly today. I also am ordering a second key/fob from MSS. Just gotta find time to "RIP" my modules out of the car. LoL Thanks Pizzaguy! I can't figure out how you have soo much time to answer so many of our technical questions! Thank you!
