Old Jan 6, 2023 | 10:21 PM
Ronman's Avatar
Ronman
Default Re: SKREEM Conumdrum!
Originally Posted by Romad
Yes I talked to MSS when I asked for a quote and he also said that based on my classic info that it indeed might be a faulty SKEEM module. He said that next time I get the no start conditions to remove the battery ground for 15 seconds and then reconnect. If problem still persists it "is" the SKREEm module. It has been starting several times properly today. I also am ordering a second key/fob from MSS. Just gotta find time to "RIP" my modules out of the car. LoL Thanks Pizzaguy! I can't figure out how you have soo much time to answer so many of our technical questions! Thank you!
Why don’t you try this:
Turned the key with battery disconnected to drain the capacitors. Then connected battery, turned key to on position for several minutes, sounded like things were reprogramming themselves, then turned key off for one minute. Then started car as normal.
If that doesn’t work then disconnect the battery with both cables touching each other for 15 minutes, tape them together if you have to.
