Old Jan 6, 2023 | 10:34 PM
Romad's Avatar
Romad
Default Re: SKREEM Conumdrum!
Originally Posted by Ronman
Why don’t you try this:
Turned the key with battery disconnected to drain the capacitors. Then connected battery, turned key to on position for several minutes, sounded like things were reprogramming themselves, then turned key off for one minute. Then started car as normal.
If that doesn’t work then disconnect the battery with both cables touching each other for 15 minutes, tape them together if you have to.
Today it has been starting several times. Should I try your suggestion next time it fails to start or anytime?
