Old Jan 7, 2023 | 03:13 PM
Ronman's Avatar
Ronman
Default Re: SKREEM Conumdrum!
Originally Posted by ZERACER
Thanks, I guess the RCM did the trick. Yes, remove the pin and spring, you do not need them. Did the wire on the black ring come loose?
Do you even read the previous posts? He changed the RCM and has the same issue. You seem to be on a quest to answer every single thread.
