Old Jan 7, 2023 | 03:15 PM
Ronman's Avatar
Ronman
Default Re: SKREEM Conumdrum!
Originally Posted by Romad
I was able to remove the tumbler and locking assembly. When I tried removing the FOB antenna ring it would not pass over the stuck key. I fumbled around with it and the black ring, below the antenna, moved and the fell out into my hand!!! So my question is what is the fix to keep this from happening again. Do I epoxy that black ring in place so it doesn't move again? It turns about 1/4" left and right. Should I remove the spring and pin under the little trap door?
Side note: Installed new seat relay, while I could get at it, and the seat works again.
The antenna ring pops on and can move a little bit. It is attached to the skreem. If you glue it on there then you will have to break it off later. I think Mercedes still sells them. When it comes to ignition switch situation, yes finish performing the sticky key fix so this doesn't happen again.
