Old Jan 7, 2023 | 04:48 PM
Romad's Avatar
Romad
Default Re: SKREEM Conumdrum!
Originally Posted by ZERACER
Thanks, I guess the RCM did the trick. Yes, remove the pin and spring, you do not need them. Did the wire on the black ring come loose?
Yes all the wiring came off even though the back was a little tough. I took the spider trap door off and nothing was inside. Looks like there never was anything inside from the factory. I put the switch assembly back in and it starts just fine and the key comes out every time with no problem. (This time! LoL) Now I have to do some dash tupper ware fixing. The dash ring broke when magilla gorilla tried delicately to remove it. Also I noticed several other broken places that will need ABS plastic epoxy as well. That's why I notices a lot of play in the dash and lower parts.
