Old Jan 7, 2023 | 10:49 PM
pizzaguy
Default Re: SKREEM Conumdrum!
Originally Posted by Romad
With the key stuck in the switch I could not manage to remove the assembly as the key was hitting the bezel. Anyway I'll leave the bezel off for now because I will remove the SKREEM module should I have no start problems in the short term. I'm pretty sure I can paste the bezel back together and not be too noticeable. Two of the attachment lugs are broken as well as a 3" piece on the backside. I only want to reinstall it back "once" should I have the SKREEM repaired.
Another side note: While the bezel is off I want to investigate my idea of installing a small led light on it to illuminate the dark LED gages. As is now I have to use my parking lights on during the day to be able to read them. It would be on all the time the ignition in in the on position.
If you are talking about the black ring around the key switch, that is the RFID antenna for the chip in the fob. If it is compromised, order a new one. You are about to waste a LOT of time. I think Josh at the MSS has them in stock.
