Old Feb 6, 2023 | 10:35 PM
pizzaguy
Default Re: Code P0455 Woes! My free Crossfire has many problems
Originally Posted by elbailey23
Thank you Pizzaguy for your reply and detailed suggestions. Yes, I’ve gone through the Evap section of the manual a few times but will go through it again. When you mention the sensor, which sensor are you referring to (or are you saying basically all the sensors in the EVAP system?). I don’t have a lot of experience unfortunately with a multimeter but may be able to figure it out and see what you suggested. Will give it a go. Thanks again!
The pressure in the tank during the EVAP test is measured by a sensor in the middle top of the tank. It's easy to see it in a Roadster.
There are two sensors, one for fuel level (has two wires) and one for tank pressure during the test (has three wires). You are looking at the level on the wire in cavity 1.
