Old Feb 8, 2023 | 10:46 AM
  #55 (permalink)
pizzaguy
Default Re: Won't Start problem / Fixed and No start back again!
Originally Posted by getaway
Sounds like crank position sensor, go bad when then get hot, cool down and car starts again, happened to mine the other week. Apparently very common, so much so that people carry spares.
Who are you responding to?
See, this is why I warn new members to be careful of the advice they take on here. The discussion is about what is obviously a SKREEM or CAN BUS related issue (unless you are responding to a post I missed, but again, if you do not quote who you are talking to, we have no clue what you are responding to). His starter is not engaging, the Crank Sensor does not stop the starter from engaging, the crank sensor simply tells the ECU what position the crankshaft is in and what speed it is turning (with additional data being provided by the Cam sensor).
