Brian P
Okay, a few questions while I have a few bucks to spend.
1) I have a laptop & can buy & install the software. Can it be installed on a flash drive?
2) I want to be able to check codes, reset the computer and minor things (no brake bleeding, hehe). I still need the Autel to actually help to reset the TPMS, right?
3) Big question… We have a 2003 Toyota Tacoma, 2005 Crossfire & a 2021 Hyundai Kona, will the software work on them? Or, am I better off buying a true scanner than the Autel for the Crossfire TPMS? I’m looking at bang for the buck. Thanks!
I can try to answer some of your questions...
1) I initially tried this. I was able to install Windows and the applications on an external flash drive but it was way too slow to be usable. I ended up installing it on an extremal SSD, connected via esata and booted from that device when wanting to use the emulator (also remembering to disable network access). I've since re-installed the emulator on a Dell Venue tablet, dedicated to that use.
2) You will need some device to 'chirp' the new sensors. In a previous post, someone mentioned using an Autel TS601. In my case, I want back to where I had the new sensors installed, along with the tires and they triggered it while I operated the emulator. I believe the device was some sort of Autel. I've heard that a strong magnet can also do the job but I have no firsthand experience.
3) I doubt that the emulator with work with anything other than a Chrysler. There are only a few vehicles to choose from when you start the emulator. I believe the other is a Sprinter van. Someone more knowledgeable will need to answer that question.
