Old Feb 13, 2023 | 08:33 PM
pizzaguy
Default Re: Radio replacement
Originally Posted by Astrofriend
Hallo, I'm back,
I have read through the forums here about the Infinity radio and its booster, but don't find exactly what I want to know.
I investigated the original booster and its connection to the speakers. The connector where all speakers are connected to, at top of the photo. Has anyone found an adapter cable for it or only the connector itself, the male ?
I don't want to cut any of the original wires so it had been very convinient with a male connector that fit this cable (top).
I am not clear on what you are trying to do. If you are putting in a new radio head and a new amplifier, you do not need or want an adapter. If you are going to upgrade to a better system, you can 'start over' with the wiring.
The factory system uses dual coil rear speakers, most amplifiers you buy today are designed for single-coil speakers, so the wiring will change. You will want to replace your rear speakers with single coil speakers.
One more question, the wire diagram I had at the beginning of this thread, is it correct how the speakers are connected ?
/Lars
THere are errors in the diagrams in the service manual. See post 7 in this thread for the corrections:
https://www.crossfireforum.org/forum...-channels.html
But again, it is best to start over. I would run new number 12 wires to the rear speakers (and I did, I have a new system in my car as well).
