Old Feb 16, 2023 | 10:31 AM
pizzaguy
Default Re: Not start, no cranck
Originally Posted by nicolas-e63
The bendix engage and motor turn ... but no ignition or benzine (??)...
I think ECU told to the car to not start.
All rest of the car seems OK :
I heard the fuell pump few second
All electric seems to works (windows, seat, ligth etc ...)...
Do you know what the ignition missing switch I have (circled in red on the net above picture) ? What does this "key in ignition switch" block ? Do my problem come from this. Perhaps, I could do bridge with a wire or add a switch on the connector ?
Thanks
Nicolas
When you press the pulse relay, the starter will engage no matter what else is wrong. But the ECU will not fire plugs unless all is OK. This test just proves that your battery and starter are good.
