dedwards0323
The only thing I will add is if you purchase an updated Metra Harness Adapter (70-1786), you DO NOT have to switch the Red & Yellow wires. This harness is wired correctly. (see attached)
Think I'm going to give up with this radio and buy a plug and play with the car's original radio connector. Have no idea what the two far right wires are for. None of the color codes seem to match up with what I have. The problem seems to be getting the amp working with the radio I have. (Cheapo radio)
As I see it the Yel/Blu is switched ACC
The next going right is constant 12v
The next is ground
The next is two twisted pairs are probably left/right channels
The nest two skinny wires are ?????
