Old Mar 12, 2023 | 05:31 PM
  #110 (permalink)
WD40's Avatar
WD40
Default Re: How can I disable the TPMS? (Tire Pressure Monitoing System)
Originally Posted by Bayukbros
I have tried to do this; '06 Roadster; got the dome light down and the only connector attached to it was black in color; only three wires in the connector with five positions; the number one and five being blank. Positions two, three, four with wires; attempted to
pull wire two out without success; I do not see a pin to depress for the wire to slide out ? The color of number two wire is light brown ? Got
frustrated and subsequently put everything back together ... now in this thread I see ( and indicated orig. the connector is ' white ' ? )
did not see a white connector with a grey/ yellow striped wire. Was it tucked forward towards the homelink / garage part ? Answers please ... I'm willing to try again to get that annoying icon on the dash to go out ... thanks bauukbros in RDU
You're messing with the wrong electrical connector. The connector you want is above the dome light inside the header-railing. Look at these 2 posts (with pictures) and it should become clear:
https://www.crossfireforum.org/forum...tml#post793109
https://www.crossfireforum.org/forum...tml#post931761
