Old Mar 16, 2023 | 02:28 PM
pizzaguy
Default re: UK Roadster Thread - drilling into the trunk
Originally Posted by amx1397
I don't know where the line is on the roadster but look under the carpet next to the door (or maybe ask a mechanic in the dealer (10 euro to him) he could tell you where the vac line going back to the trunk (boot) is.. if u find that line cut it (u can put fitting in later for repair) you can get a little air compressor like the one in the trunk i don't remember which it goes pressure opens or vac opens the trunk this way you destroy nothing. if u have a manual look it up or maybe someone state side could find it hope this helps jim
No, Jim. The pump is in the cavity in the trunk, below the trim. In a Roadster, this line goes up the wheel well and into the trunk lid at the passenger side hinge - there is no way to access it.
Also, if the electric lock is his issue , that won't help anyway. The electric lock slide a cam in place to stop the bottom from moving.
