Old Mar 20, 2023 | 09:20 AM
zip439's Avatar
zip439
Default Re: Throttle pedal position sensor
Originally Posted by slyfox1812
are you able to just replace the sensor, or do you have the replace the while pedal assembly. It's also had the the same code since I bought the car, and reoccurs whenever I clear the codes
You replace the entire peddle: the "sensor" is the peddle. MB part # 170 300 01 04. Prices range from 240 at Mercedes, 169 at FCPeuro for new, to about $100 or less for used on ebay.
