Compressors seldom go bad, be prepared for the chance the A/C issue is sensor/electrical in nature. There are a LOT of reasons the ECU will not engage the A/C pump.
Also, know that a clutch will run you $900-1500 so if the clutch is grabby or really worn, keep that in mind.
Read thru some of the "Sticky" threads here with titles that indicate information for buyers:
https://www.crossfireforum.org/forum...introductions/
