Old Apr 29, 2023 | 01:42 PM
onehundred80
Default Re: Vacuum Pump / Central Locking (Part ref: 1708000848)
Depends on how the car is programmed. My car is programmed that ONE press of either LOCK or UNLOCK activates ALL locks. In this case, it does not matter how you plumb it, as all ports act the same.
IF pressing the button twice does not open all doors, I'd say the CLP/SSM is bad or you have a leaky hose somewhere.
All these secrets are found at the end of Da'ves list under "List of resettable features" here:
Not quite true the gas cap lock only locks when the car is locked from the outside and only unlocks when the car is opened from the outside. It remains unlocked when you are driving the car.
The pump has three circuits, drivers door, passenger door and hatch and the gas cap. The first two circuits can be run simultaneously or independently as you state.
