Old May 10, 2023 | 08:52 AM
pizzaguy
Default Re: Crank but no start
Originally Posted by qldcrossfire
Does the on / off 3 times and back on (to all lights on, not actually start) with the key work on the crossfire like it does every other chrysler/dodge to display all codes on the dash? I will check that on friday if you dont know.
No, it's a Mercedes system, not a Chrysler system. The only Chrysler systems are the TPMS and the Occupant Restraint devices. If you have fuel, then you have ignition (or should). Now, VERY RARELY, fuse 11 blows, that is the primary power to the coil packs. It is VERY rare but that fuse has blown in the past.
