Crank but no start
Old Aug 5, 2023 | 06:15 PM
zip439's Avatar
Default Re: Crank but no start
If the rubber band test fails to get the car started, the fuel pump contains a check valve; Seems to me that is going bad.
The fuel filter contains a regulator.
Old Aug 7, 2023 | 08:52 PM
Bilbob's Avatar
Thanks Tighed1 !
After a bit of investigation I see that when i turn the switch to on, the fuel pumps runs for a second, or so, then stops. Sometimes the car starts, sometimes i hve to restart.
I'll take you advice and replace the pump and filter with Bosch parts.
Thanks, again, Bill
Old Aug 8, 2023 | 11:36 AM
tighed1's Avatar
It's normal for the fuel pump to run for 2 seconds when the key is first turned to the ON position.
It won't run continuously until the car starts.
No704
24
Oct 22, 2022 02:25 PM
XF90
Oct 16, 2022 09:58 PM
Paulgordon
Jul 11, 2021 10:00 PM
gompang
15
Jul 27, 2019 02:18 PM
Barbarasouix
22
Jul 10, 2019 08:25 PM
