MDKEEHN13
1) I just noticed for the first time when I depress either window switch my dome light flickers. This may have been going on before. 2) So now, another dilemma to address. UGGGH
THANKS
1) That is because the feed from the 200 amp fuse to splice block 100 is nothing more than two parallel runs of #10*. Block 100 powers almost every battery feed in the car (other than ABS, Cooling Fan and Pulse module). The power top motor/pump and power window battery feeds should come from a separate fuse in the little fuse box next to the battery, but they opted to put those high-current devices in with everything else. Had they done the same thing with the ABS controller, you'd see even more flickering.
(*Actually, the 2007 service manual says two #10s, but my SE has only one #10 so I am not sure if ANY car actually got the two conductors.)
2) No, you are just over-critiquing the car and that is leading to you noticing normal characteristics of the car and thinking they may be problems.
