Old May 17, 2023 | 06:47 PM
pizzaguy
Default Re: Roof issues again
Originally Posted by Platterus
I tried opening and closing roof several times with engine on trying to reset my roofs memory, but still am not getting it to reprogram. Another issue that may be related is that when I try to use 10 mm wrench to lock deck lid down, it doesn't click like it used to originally, unless I slightly raise the deck lid. If I try driving like this, an alarm chime comes in. Any advise? My thinking is that I might have to remove center deck lid cylinder and have Klaus rebuild it again. If I try to manually lower roof, the alarm still chimes because, I assume, the deck lid latch isn't closing properly due to 10 mm issue previously described.
Again? WIthout knowing what went on before, it's impossible to help you. If there is a thread here you made on your problem, go back to it and post the comment above there - that way, we know the history. Just saying the top is not working "again" is so little information, it's not worth even trying to help.
