Old May 31, 2023 | 10:04 AM
pizzaguy
Default Re: closing top caused mirror to break off.
Originally Posted by Recondo
A couple of days after installing the mirror as I closed the top for only the second or third time it slapped against the frame and the shock, or perhaps flexing of the windshield frame (?)
You either used the wrong product to attach the mirror, or you used the wrong technique. You cant flex the frame - you can roll the damn car and that frame will usually stand up to the stress - that is a safety item. And as an aside, if you are slamming the top down that hard, you should know that lowering the top to the frame is a TWO HANDED operation. Slamming the top down like that will cause problems eventually.
