Old May 31, 2023 | 05:01 PM
  #248 (permalink)
Zen Beer's Avatar
Zen Beer
Default Re: DRB III Emulator?
Thanks everyone, I have repaired all the wiring with solder and automotive grade heat shrink that I can see, but you are right there may be more.
@pizzaguy could I try my emulator on your crossfire, or any other Dallas/Plano Peeps around that I could verify that it is this car, and not me. Also thinking about the canbus communication, but all the tests say the wiring is good at least between connectors which leads me back to the ECU. I have sourced a replacement, but need someone to program it unfortunately. Also several of my odbii systems can communicate with some of the systems as allowed, but those may or may not rely on the ECU since they are just able to read for trouble codes. Although now that I think about it I am not sure they are returning any codes either which they should, although they are communicating or say they are. Need to verify.
@UrbanE I 100% don't think it is the emulator. I looked into replacing the harness, but from what I see it is a single harness front to back for the main wiring harness. Don't want to do that unless absolutely necessary.
