JLeighs
Hi, I think i have been confused tbh. The controller in the boot (A1938200326), I believed, looking at posts on the forum that this was the CLP/SSM. Having rechecked the form above, it looks like the CLP/SSM is actually in the boot deeper part under the carpet..
I believe the BCM is next to the ECU in the same box as the RCM.
My friend has a donor car (previous owner lost the only key), so they may let me borrow other bits if I talk to them very nicely.
Again, your advice would be very much appreciated as to which module I should concentrate on. I am thinking the PTCM.
If things went to hell when you put the siren in, it's not the PTCM. The alarm siren is wired directly to the CLP/SSM and that's in the 'boot' on (in your country) the driver's side down below the trim and foam insert.
That module is generic, you can exchange it between ANY Crossfire SRT/Limited/Coupe/Roadster.
