Old Jul 24, 2023 | 01:26 AM
M60A3Driver
Default Re: Car Rocks back and forth at idle, and occasionally stalls while driving
Originally Posted by thegalaxy1987
It is a Roadster 2005 automatic. The whole vehicle moves back and forth at idle. The vehicle is little slow at responsiveness to the gas pedal as well if that helps any and I have Already soldered my bad RCM for my random stalls and not starting at times. That fix the stalls and not starting but did not fix and back and forth motion.
I'm not sure what that could be since I have a manual transmission. It sounds like some kind of sensor problem to me. Have you spilled anything on the shifter?
I have a suggestion that might get your post noticed by one of the senior members. Post this again in The Engine, Exhaust, Transmission and Differential section:
https://www.crossfireforum.org/forum/engine-exhaust-transmission-differential/
Hope fully someone who has an automatic or maybe has had the same trouble will see it. Remember to include the info about your car in the post.
Here are a couple of links to posts about auto-transmission troubles:
There's a lot of info on this one: https://www.crossfireforum.org/forum...r-shifter.html
Here's another: https://www.crossfireforum.org/forum...-problems.html
Sorry I couldn't be more help. Good luck!
