Thread: Lock/Key Issue
Old Aug 9, 2023 | 08:12 PM
pizzaguy
Default Re: Lock/Key Issue
Originally Posted by magnuman
The keys are fine.
The original spare has hardly ever been used and the batteries are new.
The one that I have always used, has new batteries and the contacts are not compromised and making contact fine.
Both keys red diod lights up when pushed.
The car recognizes that the key is correct as the car start and performs fine.
I have used the drivers side door lock/unlock before and never had an issue with it locking the passanger and trunk locks as it should.
I knwo the pumps in the doors and hatch are working as when I pressed the lock/unlock button on dashboard everything works as should.
This all came about when I had a bad/dead car battery and replaced with a new one.
I'll check voltage today.
Changing the car battery should not cause a problem, but often does.
Also, when I lock from inside and open the drivers door all locks unlock as they should.
Both keys will not program.
I once saw a video about programming the keys from outside the car aiming at front end?
YOur re-sync procedure is fine and I have no clue what video you saw, but the procedure you are using is the right one.
Can security system or bad ground wires cause any of these issues?
This is the procedure I've tried for the key.for the key.
Resynchronization:
Insert key into ignition. Don't turn it.
Press the lock button on the switchblade remote key twice in 2 seconds.
Turn the key to ON or RUN within 30 seconds.
Take the key out. Exit vehicle and have the doors closed. Test the remote.
The fact the car starts and runs kinda verifies that the ground to the battery, and the ground from chassis to block, are OK.
Yes, the security system IS your problem and it consists of: SKREEM, Body Control Module (BCM), Central Locking Pump/Security System Module (CLP/SSM) and we know the BCM and CLP/SSM are OK because the console button works.
I still say the SKREEM is the issue here, it's either not powered up or it partly died when you changed the battery. I'm not saying the SKREEM is DEAD completely, I am saying the "secure start" portion is fine but the Remote Keyless Entry (RKE) function is impaired. I don't like disagreeing with Josh, but this time I do.
