Old Aug 13, 2023 | 08:05 PM
pizzaguy
Default Re: No crank after new keys
Originally Posted by Jonathandugan20
I purchased a 2005 limited with one key that wouldnt lock the doors for my step son. So I had rob at NEEDSWINGS reprogram my only working key and cut and program 2 additional keys. I reinstalled the skreem module, antenna ring and ecu and the keys paired flawlessly to the to the vehicle....except now it won't start!
I had zero issues before re installing the skreem, antenna ring and ecu. I put the battery terminals on with the key mistakenly in the on position. I was worried I might have fried the ecu so I tried to connect a code reader to my obd port and the reader now cannot connect to the ecu. I decided to replace the crank and camshaft sensors on a whim...no luck. I checked the rcm solder connections and fuses all good. I checked to see if the rcm was functioning with the key on. Everything functions when I manually close the relays. The 2 relays close when the key is in the start position (verified while the wife tried to start it). I ordered a new rcm incase my current one is somehow faulty.
Any ideas on where I should proceed next? I contacted Rob at NEEDSWINGS to see if he has seen this before. Any help is appreciated!
Can't help you with a post like that.
Is the starter engaging or not? Please don't say "it won't start" you are going to get ignored.
And Rob has seen it all before, we all have. But you are telling us NOTHING. What is the car doing? Is the starter engaging and it won't start or is the starter not even engaging?
