Old Aug 18, 2023 | 08:19 PM
pizzaguy
Default Re: Door switch on console switch group
Originally Posted by red_2005_convertible
Hi 180,
I currently happen to have my console switch out. I measured the resistance of my switch between pins 4 and 8, and got 200 ohms and 0 ohms - same as your measurements. I measured the resistance from console switch group (csg) connector pin 4 to ground, and got less than 1 ohms. I measured the voltage between csg connector pin 8 to ground, and got 12.34V, no key in the ignition. I tried shorting the two pins together, but the door locks didn't close.
Shorting them unlocks the doors. Applying 200 ohms between them locks the doors.
