Old Aug 19, 2023 | 02:34 PM
  #1209 (permalink)
pizzaguy
Default Re: Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
Originally Posted by BrushRoadster!
Something else I also noticed is that when you go to the "Start" position, you initiate a start sequence, similar to starting an aircraft jet engine. Once you have hit the start position, if you release the key, the "start sequence" will continue and the engine will be started, regardless. It is NOT like a Ford or Chevy, where if you turn the key and start cranking, then release pressure on the key, the starter will cease operation and everything goes back to a dead state. On the Crossfire, when you turn the key, the starting sequence is initiated, and off you go.
NOt my Crossfire, what you describe, is an attribute of the cars with automatics, not manuals. And what we learned in the manuals, is if you release the key and then turn it back to "Start", nothing happens. YOu must start the cycle over by going back to "off", so the sequence is there, but it can be interrupted with the key in the manual, where it can't with an auto.
