Old Aug 20, 2023 | 11:42 AM
pizzaguy
Default Re: Door switch on console switch group
Originally Posted by red_2005_convertible
I guess maybe I got the open and close resistance values mixed up. When I tested shorting pins 4 to 8, everything was open so nothing would happen if a short is open. Tomorrow I'll try using a 200ohm resistor to jump pins 4 and 8 and see if the locks close.
-Jerry
WHy not use the FOB to lock the doors, the short the pins to unlock? Not that you can't use a 200 ohm resistor for "lock".............
