Old Oct 29, 2023 | 12:35 AM
pizzaguy
Default Re: Oil light goes on then off when the oil level is okay
Originally Posted by ray48317
I have a 2005 crossfire with 53000 miles on it. When I start to drive the car the need oil light goes on and shortly after that, it goes off. The oil level is full. This happens a few times and then the need oil light stays off. What could be wrong?
The oil light, that is, the "genie" light, is an indication of low oil level (not pressure, the M112 engine has no oil pressure sensor). Our cars are known for the oil level sending unit failing, very common.
Unfortunately, they are expensive and not all that easy to change - you must drop the oil pan to get to it. I swear, if mine fails, I'm going to ignore it. I have a pressure gauge on everything I own.
THis is the part:
https://www.fcpeuro.com/products/mer...der-2759050000
