Old Oct 30, 2023 | 08:09 PM
pizzaguy
Default Re: Brake Light & Air Locking System Issue
Originally Posted by mikemadeit94
After seeing another thread that stated a pin was missing from corrosion I double checked my white connection and I'm in fact missing a pin... the question is, is this pin in use and would it effect NOTHING working at all? It looks like the green wire in the far back right of the pic is the one that would not be connecting. If so is there anyway to save this? Could I maybe just cut the harness and solder that wire directly to the connection? Or is there a way to put another pin in it?
Im in a lot of pain right now and short on time but I will offer these two things:
1) The Coupe harness and Roadster harness are different - the coupe harness is missing a wire; always get the harness from a parts car that matches what you have.
1A) The CLP/SSM in the Coupe and Roadster are the same part, all CLP/SSMs are the same.
2) The connector/pins in the photo above belongs in the trash can. You need the last 2-3 feet of harness from a car that has had NO water damage. You CAN NOT clean/fix corroded pins; I earned a living as a radio/electronics technician from 1983 to 2010, sure, you can make it work, maybe, for a little while - then weird stuff starts happening.
Again, in a lot of pain and I gotta go relax.
