Old Dec 2, 2023 | 06:02 PM
Crossfirefan1969's Avatar
Crossfirefan1969
Default Re: 20 inch wheels on the xfire?
Originally Posted by CrucialCrossfire
...More general info: You can go as wide as a 275/35/20 in the rear and up to 10 inch wide!...i used a 265/35/20 (see below) in the rear cause of tire choices and availability of my BFG kdw tires. (Bad a$$ tires).
Attachment 51692
Attachment 51693
Hello there, I'm new to the forum and was wondering whether you could kindly help in the same issue. I'm planing to swap the stock with 9x20 MMR VP3 all round 20 set. However, mock fitting the rim today in the front end, it seemed quite tight. Do you think it would normally fit with 225/30/20? Many thanks!
